W56 stock clutch
W56 stock clutch
Just about to do a VW TDI swap, i am wondering how much torque a stock clutch in a W56 will take? I am hoping the modded 1.9 will put out about 270 ft-lbs.
Thanks,
Lucas
Thanks,
Lucas
What size tires are you running? Have you seen any of the Marlin clutches? Those should be more than enough if you are running anywhere from 31-35 tires. Guys wheel on stock clutches with 36's and 38's with 22re's and some built 22re's with around 150hp/170ft-lb.
I've also heard the stock clutch is one of the best, I'd take it over a Centerforce. Not sure about Marlin though he always seems to find a way to upgrade the OEM stuff somewhat. Hope this helps, I don't have any first hand experience but I hope to swap an older 1.9T non TDI in my truck one day and I wanna push a bit more power out of it too.
shadowbirdie
07-21-2015 10:38 PM
WTB[PacNorWest]: w56 c manual trans with t-case and drivelin
89hilux1
07-19-2015 01:32 AM
