seqouia 2001 4.7l V8 to 4runner 2001 2wd engine and trans swap
hello every one , i wan to change to my 4runner 3.4l V6 5vzfe 2wd a engine and trans from a sequia 2001 v8 4.7L and A341F trans
Want to convert my 4runner 2wd into AWD or 4x4 on demand is this posible.
Can i do this ???
Thanks a lot
ger9147
Can i do this ???
Thanks a lot
ger9147
Hello, I read on one of your posts that you had done a conversion that was putting a 4.7 liter into a 4 runner. I was wondering if you thought it would be possible to put the 4.7 into 97 T100 SR5 4x4 that came stock with 3.4 liter v6. It now has a blown head gasket and 268,000 miles.
Of course you can, i just select this trany the a341f from sequoia because you have a botton to connect the the central diferential and if i want i can drive in 2wd or 4wd.Just take and put attention to the electric wires take a picture from the donator wires and thas it. also remenber to put the computer from the donator. Regards
Big Little Bear
230
11-13-2023 11:42 AM
justdifferentials
Just Differentials
06-13-2022 07:40 PM
