Hi all, lhave a 2004 lx470 with the 4.7 v8 I need some help with. I want to do a diesel swap, most probably a 1hd-fte. I noticed the 4.7 has the following pins on it that go to the abs/atrac/vsc ecu : trc+, trc-, eng+, eng-, neo . I want to try maintain functionality of these systems so need to ensure they are connected. I noticed that 2004 and newer 1hdfte engines have these pins, as does the 2adfte and a few others from those years
What I'm trying to find out is whether the information being transferred via these pins is the same, I.e. if I wire diesel ecu pins up will the abs/atrac/vsc ecu get the information it needs?
