91 tranny and 3.0 7mge
Here is proof
"The write-ups above go through the actual install fairly well, so I’ll try to avoid repeating too much. What you’ll need to get the 7MGE bolted in:
- Supra bellhousing, clutch fork & throwout bearing retaining spring, clutch slave cylinder & hose - Supra’s used a “W” series transmission which uses the same bellhousing-trans bolt pattern as the “W” series truck trans – you will use your stock “W” series trans and transfer case – use a pre ’89 bellhousing, after this Toyota changed the clutch and pressure plate design, pre ’89 is the standard “fork and throwout” style"
And his swap thread...
https://www.yotatech.com/forums/f161...-supra-162638/
BeMiceElf
10-10-2015 09:40 PM
Iceman4193
07-15-2015 04:48 PM
