90' 22re to 86' 22r3
90' 22re to 86' 4runner!
so i got basically everything figured out, except!
the injector plugs.....im using the wiring harness from the 86, but the inj. plugs do not match on the 2nd gen motor....
should i
A. look at a diagram, cut the factory plugs off, put plugs on all of the wires and plug them into the injectors..
B. go junk yard diving and cut the factory injector plugs off a 2nd gen wiring harness..
i believe the injs. are aftermarket so i'd like to keeep em in the motor...
thanks for any help guys!
should i
