22re vacume lines help!!!!!
i need some help with all the vacume lines on a 88 22re the intake was off when i got it and dont know were all the vacume lines go and if some one has some pictures of the top of the motor and vacume lines would be great please help
These are the only 2 i have from when i replaced the head gasket.
This truck is the 22R-TE and im not sure if the turbo vacuum routing is the same on the turbo as the non turbo.
and im only 95% sure their right but it worked for me!!
Hope this helps!
Edit: Note don't worry about all the ghetto wiring i have since then fixed that, the P.O. had some crazy stuff going on in this truck, notice the 4" ground with 2 butt connecters!!!
Hope this helps!
Gotta run, but I have a couple youtube videos that explain where they all go, if you wanna look through em... imachefmang is my id on Youtube.... It's more toward the middle, I would say, of many videos, lol. I did 3 actually, and 1 is the best of them all.
Here's one for now, not the one I'm looking for...
Yeah, I suppose you would.
* So, you're not planning on power steering ever?
* Do you have A/C? (that has 2 lines running to the plenum as well, which have to be hooked the right way or you'll hear the filter basket tip 'HISSSSSSSS-WEEEEEEEE' away! lol.
* You have the IACV and large lines and plug to remember, too(just a heads up, it's a bit of a tight squeeze once everything's on )
*You might also have a cruise control line. That plugs into the 3 port attachment I showed.
When I rebuilt my 22re the first time I had the exact same problem, engine was disassembled, hood was in the bed. I spent hours working through the vacuum diagram in the Chilton manual. Afterward when I installed the hood I noticed a very handy decal showing the vacuum manifold and the lines that went from it to the individual parts. That decal was 100 times easier to read than chilton's diagram; so is there by chance a decal under your hood?
i find it easiest to label the end of each vacuum line with a letter, and a corresponding letter where it goes. and PICTURES!! helps a lot.
Hope you get it figured out!!
no i want power steering in the future just not right now i dont have the money to fork out for high steer and ˟˟˟˟ thanks this is helping me out
No problem, Mike! We've ALL needed help on here, some of it desperate! ... And, well, some of us more than others YES< I mean me! hahaha. But actually, learned quite a bit through this site/it's peeps! lol.
Here's the hood diagram... DON'T feel bad if you have it and looked right past it(more than likely someone painted it! GRRR! lol. But if it's there, you're not the only person to have missed it! lol). >>>>>>>>>>>>>>>>>
09-04-2015 09:27 AM
