want asking for Roof Rack Setup on 2010 Toyota Tacoma
Hello YotaTech Community
I am planning to install my 2010 Toyota Tacoma with a roof rack setup and could use some guidance from the experts here. My main objectives are to increase the amount of storage for camping equipment.
Which roof rack brands are best dependable & long-lasting options for a 2010 Tacoma. I Am debating between going with a modular setup that I can customize as needed or a fixed, more permanent solution. What are the pros and cons of each type, especially in terms of versatility and ease of use & How can I ensure that roof rack setup can handle the weight of my gear without compromising safety. Which add-ons and accessories have you found to be the most helpful for your roof rack setup?
Also i have found this https://www.yotatech.com/forums/f116/roof-rack-3rd-gen-extra-cabalteryx
Thanks in advance for your help
regards
Anjity
regards
Anjity
I got the OEM one. The bars rotate out of the way so you don't get a mileage hit when you are not using it, and then I can deploy them for the kayak or whatever else I need to put up there.
