3vze/5vze oil pan swap necessary for SAS?
Hi yall, searched but couldn't find definitive answer to this. ive got a 92 pickup with the 3vze. Ive almost got all my SAS parts together and will be doing the swap in the next month or two. I also have a used 5vze that I will be building and swapping in AFTER the SAS. Do I need a different oil pan to fit the solid axle high steer on either of these 2 engines? I will be running the 3vze for probably at least a year with the SAS before I have the time and funds to rebuild the 5vze. Do I need the t100 2wd oil pan for both these engines? does the t100 pan. fit on both? This is the only detail I can't seem to iron out before I cut off my IFS and then there's no going back. thx for any replies.
Check out the 3.4 swap section and especially the stickies at the top of the page. Good luck with your swap. https://www.yotatech.com/forums/f160...l-swap-237832/
dntsdad
04-30-2012 06:49 AM
