1990 Pickup SAS
Yea the springs will break in and settle over the course of a couple thousand miles. I just saw the arch on your springs and was like damn! I have the rears up front on mine they are almost flat and it still clears 37's with no rubbing at full flex.
trucks looking good! id say 63's would be a good finishing touch.
#25
Have you wheeled them yet? seems like they'd be kinda stiff cause those waggys are steel beasts
#28
may just be the camera angle, but is the back seems a little shorter?
i'd level it or put the back just a hair higher than the front,
nice job on the sas, looks good!
#30
Was just looking at your '81 project, would have been cool to see it before it went away-just realized you are in Portland.
#32
truck looks good and perforemed really well this weekend! glad you could make it out!
were thinking about making another trip on the 4th of july weekend if you wanna go!
#36
#37
I ended up just putting the ADL in but I didn't want to mess around with having to modify the emergency brake so ended up taking out the overload. So I think its a little better but not much since taking out the overload canceled out most of the add lift I was going to get. I'm still using the stock spring hangar, so once I get around to putting new ones on a little farther back it will fix my shackle angle and give me a little lift.
#38
On the leafs, is there an associated capacity for each one (i.e. one leaf at 1/4" thick able to handle x amount of lbs?). My gut tells me there is a direct tie to the length of the spring too . . .
Algranger, I love the gusset recommendation on the front spring hanger (not sure how much of an impact this is to a SAS, but i love the engineering logic-strength!).
Sokoji,
I watched this 4x4 show (Extreme 4x4 on Spike network) that showed where to tie into the frame when doing a SAS, they mentioned that you wanna let the truck rest on the spring then mark the location above the final setpoint when the full weight of the truck is resting. Out of curiosity, is this how you did it? or did you use a diff method?
Sokoji,
#39
I've got a 1990 4x4, and some of the front end components are looking a little rough. I've been thinking that if it won't pass inspection next time (due to the front end), that I might like to go your route with a SAS. Could you tell me what year Wagoneer leaf springs they are? And what vehicle is the axle from? You made it look easy
Thanks,
Josh
Thanks,
Josh
MMA_Alex
25
04-18-2017 05:07 AM
madxman21
07-09-2015 10:26 AM
