4WD Toyota Owner Article.... Guess Who?
Right on can I have your autograph?? I got my Mag today but haven't opened it yet. I think I have a pic of my Runner on that same chunk of gravel.
Cool...
Joey, that is indeed around the same spot.
It has changed up there quite a bit though.
That was a lot of fun seeing them rip in the rig and putting the stuff on.
I wish I had the mag. to look at. It's May 10th and haven't gotten my issue yet.
I was at my local Post office today. If those people moved any slower, they surely would fall over.
Actually these are the only factory wheels I dig.
I was going to go aftermarket, but why if I am happy with them?
There is not an aftermarket wheel out right now that I like better than these, and these are the correct offset which tucks the wheel in close.
I may order a 2nd set of them to go with the 285s I am switching over too.
Actually it is the post office holding you up.
The mags all ship in bulk to different areas.
http://www.4wdtoyotaowner.com/mailinginfo.html
Also when did you order?
It can take two months to get on the sub list, especially if an issue just shipped since this is bi-monthly.
Corey, I sent them a check in January and received the March/April issue of the mag.
I just noticed that other magazine users, sub's have gotten their May/June issues, but none here in Spokane yet.
It could be the "Mule Train" USPS that's holding things up, they have before.
Thanks Starbuck.
There may be something in the works for another opportunity before summer is over too.
Ring, I bet it is the PO out your way.
I got my main issue this time on the 30th of April, and my 8 bulk copies a few days earlier.
I generally get my issue though no later than the 3rd.
Did some of you still not get the May/June issue?
If so, you should have received an email from the magazine stating why.
And if any of you did not get it, your susscription will be extended out an extra issue.
The entire May/June issue is available to you online in pdf format, the link will be in your email.
