93-98 T100s All T100 trucks
Marshmallow brakes
Old 10-21-2009 | 03:29 AM
jrohland's Avatar
Marshmallow brakes
I've been trying to get rid of the sponge brake problem. That is, pushing on the brake feels like stepping on marshmallows.
So far I've done a full pad and shoe job which was needed anyway. Fixed a rust seazed right side parking brake bell crank. (In case you don't know, the auto-adjusters activate when the parking brake is used. If you don't use your parking brake on the T100, your rear brakes will not auto-adjust.) Replaced the drums (rust). Flushed and bled the entire system.
I'm quite sure the mush problem is a worn master cylinder. The factory replacement is about $212. I found an aftermarket for $115. Any of you use an after market master cylinder? How does it work for you?
As a rule I don't like using after market for critical systems but that is a big savings.
jrohland
Old 10-21-2009 | 06:44 AM
desertcamper67's Avatar
How's your rubber brake hoses? They can be damaged inside and swell but not leak. Or maybe you haven't actually gotten all the air out of the system. Do you get good pressure out of each bleeder?
Old 10-21-2009 | 08:11 AM
jrohland's Avatar
Don't see that problem
I don't see any ballooning in the flex tubes. The brakes do not pump up so I have no reason to believe there is air in the system.
Having done the bleed job alone, I can't really tell about the pressure at the nipples. I don't have a brake pressure tester. Maybe I can borrow one. I would like to calibrate the load balancing valve.
jrohland
Old 10-21-2009 | 09:30 AM
jrohland's Avatar
Try that
I got a used MC from one of the Yotatech members for a good price. When I get it, I will try that. If it does not correct the problem I will keep going with other components.
jrohland
Old 10-21-2009 | 01:44 PM
jrohland's Avatar
Well not quite
Originally Posted by Gnarly4X
A bad master brake cylinder is easy to diagnose. If it leaking... it's bad. If you can push the brake pedal down and hold it and the pedal goes down, the fluid is seaping past the piston. A spongy pedal is typically not a master cylinder problem.
Well I checked the brake troubleshooting table (see the image below).
While faulty MC is near the bottom of the list, it is there.
Actually, the MC is two MCs connected together. I believe the rear brake piston is not working.
At any rate we will know when I replace the MC. If the brake feel more solid, there was a problem. If not, that was not the problem.
jrohland
Old 10-21-2009 | 07:49 PM
BamZipPow's Avatar
How good was the fluid flow when you were bleeding out the rear brakes? Did it come shooting out or did it sort dribble out?
Spongy = air in the system...
I had the same symptoms as you did on my 1993 T-100...I started by replacing my MC first as well. It ended up being that there was crud stuck in the LSPV and not allowing proper flow to my rear brakes. I found a simple test to see if the LSPV is doing it's job.
Chock the front wheels.
Release the parking brake (if applied).
Jack up the rear by the differential.
Put the trans in neutral.
Spin one of the wheels by hand.
Stomp on the pedal.
If the wheels do not stop...it's most likely the LSPV/bleeder valve needs a good clean out.
I whacked the heck out of the LSPV with a 2x4 and then bled it out. The time before...nothing came out. After the "persuasion" with the 2x4, fluid came shooting out along with a ton of air bubbles. Moving to the rear brakes...got more air and lots of fluid flow. Pedal was gitting firmer. Back to the LSPV fer a little more air bubbles and strong fluid flow! Pedal was really firm now. Bled the fronts and system was darn near perfect! That's my story...
Old 10-21-2009 | 08:50 PM
Jason4X4's Avatar
make sure your rear shoes are adjusted properly, if not, i've seen them cause funny pedals.
Old 10-23-2009 | 06:24 AM
hotshoe's Avatar
Check rear shoes and the crappy LSPV- Most likely that's it- Same problem on my T
Old 10-23-2009 | 08:38 AM
jrohland's Avatar
Tight shoes
The shoes are new and adjusted properly. The LSPV is a possible problem. When I bled it I had to take the nozzle out and drill the rust our of the bleed holes. It bled OK after I cleared the nozzle but it could be gummed up inside the valve.
Like I said I am getting a good master for cheap so I will start with that. If it does not fix it the LSPV is next on the list.
Thanks for the help,
jrohland
Old 10-23-2009 | 09:44 AM
DIHOWARD's Avatar
We like these, we like these ALOT!
SS hoses made by Stop-Tech.
1uzRunner
63
11-10-2018 03:58 PM
old87yota
09-09-2015 12:39 PM
fabing455
09-07-2015 08:08 AM
Scatterbrain
09-03-2015 06:46 PM
Quick Reply: Marshmallow brakes
