Electrical Disaster! P0301 + P1300
Hey all! Posting this here and Toyota Nation looking for help!For Context: 96 T100 3.4 4WD
Drove the truck up on a rough gravel road to go berry picking. (Lots of bouncing around)
Took the truck to work the next day (truck was running great) and stopped to get a coffee, come back out and it’s misfiring and throwing P0301.
So I change the spark plug, swap coils from another cylinder, and no change.
I let it cool off while trying to diagnose my issue by inspecting my ignition wiring (which you’ll come to see is a mess), go to start it back up and no misfire. I finish driving to work (bills to pay) then drive it to the grocery store. I put the under dash panels back on while the wife was shopping, then misfiring again.
So here’s where things get complicated, the previous owner must have had an issue with the key/ignition switch and decided it would be better configured with 2 household light switches and a push button with standard 12/3 (see pictures attached)
So trying to get some sort of fix in the midst of this, I tried to wire it back to a standard key switch from autozone. (Not sure I have the wiring right)
Also while trying to diagnose this, it starts to pop a P1300 code.
But anyhow, after changing this wiring out, my turn signals, dash lights, hazards, cig don’t work and when the hazards are pressed the parking/drive indicator light will go bright/dim. Note: The radio, headlights and taillights still work.
Also they had the hazard spliced in on the 15amp cig fuse
Also worth noting that months prior, I redid the timing belt and valve covers but the truck has ran excellent up until this point.
I have an absolute electrical mess and I’m not very wiring savvy but I can partially read a diagram and love to learn but at this rate I’m ready to try to rip the entire harness out and start over.
I’ll try to attach all photos that might be helpful.
Any ideas and assistance as to what’s causing the misfire and the majority of the accessories to no longer work would be greatly appreciated.
Ignition switch
Ignition switches
Push button start
My attempt at getting a key switch wired in
Current state of the dash
Ignition switch
Ignition switches
Push button start
Hellvision251
10
01-02-2014 12:24 PM
BlackNite3
01-23-2010 03:39 PM
