Window motors work, but switch does nothing?
I can't put my windows down, but I know the motor works, because I took a battery straight to it and put the windows down, but for some reason neither of the switches will do anything. Is there a fuse to the power windows? Or some main power wire to the windows that might be cut or something?
Sorry no, it's the door windows. The window lock is not on. Unless the switch is messed up and it constantly on even when not pushed in.
Just what year are you working on??
Has the vehicle sat for a long time switches do corrode
Depending what year your working with most all windows are powered through the door relay if that is not working .
Do the door locks work??
This is one of those things break out the Meter .
It can by any one of several things
Bad grounds, broken wires poor or unplugged connections
FinallyOffRoad
02-04-2016 11:20 PM
kauaiaxel
02-03-2016 09:18 PM
