General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
testing door swithces
Old 01-08-2016 | 02:07 PM
zmbombr's Avatar
I think one of the door sensors is bad because the truck thinks a door is open. Doors won't lock, while driving or with alarm faub while off. and the dome light will always be on if I leave it on "door". just not willing to dive into removing the sensors and testing.
ANy other places to test these besides removing the unit from the door?
how bout a colored wire from the wire harness feed going to the door or access under the dash?
Old 01-08-2016 | 05:54 PM
wyoming9's Avatar
Red face
Sure however you want .
It might help to give just a little hint of what you might be working on.
Hint I would bet the drivers door because it sees the most use.
Your going to need to remove it to replace .
Old 01-08-2016 | 07:10 PM
RAD4Runner's Avatar
Sorry, I do not know where to check on an Escalade. Don't know wire colors on those either.
Old 01-09-2016 | 12:14 AM
zmbombr's Avatar
'02 Tacoma double cab. Pulling to replace is fine. Just was looking for beta on other acces to circuts without having to pull each one.
oldmansimek
06-20-2023 05:14 PM
sharrack
01-02-2016 02:50 PM
mapemberton12
12-08-2015 06:40 PM
☆OMI☆
11-23-2015 10:02 PM
bobbybouche
11-19-2015 05:25 PM
