General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
No power to VSV
Old 12-03-2013 | 04:27 AM
Bills86e's Avatar
No power to VSV
1994 4runner SR5 3.0L 3vze
My Vacuum Switching Valve is open at start up and the vacuum is opening the EGR valve, irradic Idle results. It runs crappy and a foul smell too.
How does this valve close, it will click and shut if I put 12v to it? Is it supposed to get electrified at start-up? New one does same thing.
I first thru parts because I was not enlightened:
EGR valve & pipes
cap
wires
rotor
modulator
R&C'nd TB & intake
C'nd DP
Fuel filter
Air filter
Vmaf
AC & heat work very good
All running lights work
The three VSV valves, Blue is next to firewall, Brown center haslines to egr & mod, green front.
Any one have a pic of the correct routeing?
Old 12-03-2013 | 05:27 AM
PlainJaneYota's Avatar
It sounds like the vacuum modulator is broken, check the OEM dealer site for the diagram and the part ---> https://parts.olathetoyota.com/index.html
Old 12-03-2013 | 11:57 AM
Bills86e's Avatar
Wife has mechanic change valve cover gaskets, he re-plugged the vac lines on wrong tubes. Who would've Thunk? 3VZE now runs perfect. No more foul smell or
erradic Idle. ALL is well! Yes, Modulator & hashpot filters needed cleaning too. TB & IAC was filthy inside.
Old 12-03-2013 | 05:35 PM
Punchy's Avatar
The Blue VSV is to the PAIR, The Red (brown) is to the Fuel pressure up and the Green is to EGR.
Old 12-04-2013 | 05:39 PM
Bills86e's Avatar
My red/brown was connected to egr. green was to fuel regulator, hencethe foul smell, vac to egr at idle.
Old 12-05-2013 | 04:26 AM
Bills86e's Avatar
thread closed
delmert
09-30-2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
09-23-2015 10:11 PM
agrout
08-13-2015 06:12 PM
Colington
08-13-2015 02:21 PM
Sidherish
08-02-2015 01:42 PM
Quick Reply: No power to VSV
