How do I replace the 120a fuse?
I accidently tried tried to jump my r99 4runner with the cables on backwards. :pat:. So I opened up the fuse box under the engine bay and sure enough the big 120a fuse is blown. I tried pulling it out but the contacts stayed in place and ended up with just the plastic housing. It appears there may be a screw holding it in but I can't figure out how to get to it. lil help here guys please.
whats the trick to getting this thing apart? I have unbolted it from the fender but for the life of me I can't figure out how to get this thing apart to replace the 120a fuse ??
things thing is turning out to be a royal PITA. I'm sure its going to end up being something totally simple that I'm overlooking too.
There's a screw on the side of the fuse box, in the front and the back. One each for the two big fuses. But, to get to it, you have to separate the halves of the fuse box. Leave it bolted to the fender, and take the box apart.
what a pain in the ass. There are 4 tiny recessed clips randomly placed throughout the box. These have to all be undone at the same time with a very small screwdriver. Then you need 2 pairs of pliers to pull up on both ends at the same time. Once its out there are 2 bolts. One 8mm and one 6mm you'll need a socket with a small extension to get to. After that its cake.
At least I can says it's done now.
Yeup... it's a pain.
I screwed up once and blew the fuse... I broke the plastic top away and shorted together the two leads inside. I drove that way long enough that I'd forgotten I'd done it... many months.
I didn't mention that before because it was very much the wrong thing to do and it was important that you did it right versus taking a shortcut that could have fried your truck.
I almost didn't disconnect the batt when I started.
But then I remembered that I was the dumb ลลลล that put the cables on backwards in the first place. Odd's are I'd fry something else if I didn't idiot proof the job and disconnect it.
ashersullivan88yota
01-18-2022 05:37 PM
madxman21
07-09-2015 10:26 AM
