Horn contacts
Horn contacts
hey guys can you help, i did not even know there were contacts on a horn but toyota said there is.....my horn has not been working for some time....so i took it apart
do you guys know where these contacts are located...thanks
You have to pull the entire steering wheel off. Remove the big nut in the center. The shaft is splined so you have to pull straight up.
There is a spring loaded contact similar to a motor brush poking upward out of the column. It makes contact with a circular brass ring on the underside of the wheel. Like any brush it wears out over time. An easy fix is to make a shim from a plastic lid (like from a coffee can or something) and place it under the brass ring to move it closer to the contact.
live4soccer7
05-11-2016 06:52 PM
