General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Headlight Harness Wiring Upgrade (w/pics)
Old 01-27-2014 | 10:22 AM
RSR's Avatar
RSR
Into your passenger's side old female plug...
Old 03-17-2014 | 03:33 PM
Tankz's Avatar
Originally Posted by RSR
Thanks for the writeup aviator. Definitely helped with mine.
I decided to go with this kit as the wire was a little heavier gauge and came w/ ceramic plugs than the other premade kits I could find.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=330813121438
Basically, I did it the same as you, working left to right:
1. Remove battery holder.
2. Remove windshield washer fluid holder.
3. Loosen passenger side radiator bolts.
4. Loosen drivers side radiator bolts.
5. Remove radiator top foam.
6. Remove coolant overflow holder (I went ahead and flushed this out as there was crud at the bottom of the container...)
7. Remove air deflector -- I went ahead and removed the whole thing as it made it easier to remove the deflector and I needed space for another project anyways (haven't detailed yet, but added an add'l square inch of air intake by drilling 1/4" holes below the front drivers side light...).
8. Run the light harness right below the stock harness and loosely zip tie.
9. Double check your end links (grounds and connections to lights for appropriate length) before tightening zip ties all the way.
10. Install grounds (I used existing ground locations and just sanded away some paint to ensure with good connection, and once installed coated w/ diaelectric grease).
11. Remove battery for working room. (While I had it out I took a wire brush to below the tray, hosed it off, waited for it to dry, and dropped a couple coats of spray paint beneath the battery too -- one of the few rust spots on my rig).
12. Install relays in factory screw terminal in inside engine bay wall next to battery (I just used a piece of flashing as it was the cheapest sheet metal at the hardware store). I want to say it was an 8x1.0 thread fitting but it is the same size as the air deflector screws (actually probably the air deflector install point for yota diesels...). I used a couple of washers between the bracket and frame to allow space for the windshield washer hose to pass behind -- female screw mount is already slightly raised from engine wall.
13. Connect the the new harness male control connector to factory passenger side light connection. Good time for electrical tape.
14. Zip tie drivers side factory light connection out of the way so it doesn't dangle.
15. Reinstall battery.
16. Install power cable to battery positive.
17. Reinstall everything else your removed.
18. Connect new harness connections to lights before install -- found on drivers side that it was easiest to install deflector with light not yet installed (the H4s extend a little further back than the old sealed beams did...).
19. Test that your lights work.
20. And done.
Here are some pics.
Harness run and zip tied between windshield washer fluid reservoir and radiator
Harness leaving radiator by coolant reservoir to air deflector
Drivers side ground to existing ground location (make sure the ground wire runs/fits through air deflector wire slot)
Passenger side ground location (the battery to frame ground location -- my next big electrical project is addressing the wiring at the battery and new battery terminals)
Relays installed
Old light connection to new relay harness
Old v New Harness
New harness, driver side, on new Hella H4 light conversion
The link says it is for 9003, thought we used a 9004. Does this work for a 1990 toyota pickup? It says yes on ebay but i don't trust them very well.
Old 03-25-2014 | 01:42 AM
RSR's Avatar
RSR
9003/H4s have the exact same connectors as our sealed beams.
Old 01-03-2015 | 12:39 PM
Odin's Avatar
Originally Posted by aviator
Because of the ticket I could'nt wait for delivery from the guy others have used for upgrade kits previously reported on here.
Does anybody know who or what brand the kit every body else is using?
The NOKYA kit the OP used has wires that are too thin for my liking. The NOKYA kit also looks exactly like the Putco harness other than the color of the large wire sleeves.
The Taiwan made Putco kit the Jeep guys are using is 16 awg with junk relays so I'm not about to use that.
16 AWG is fine for stock wattage demands but when you want to push higher wattages with full voltage I think it's going to create some resistance and heat. You'll want 14 awg minimum with 12 awg preferred for 100/90 bulbs and ceramic connectors. The last time I ran 100/90 bulbs I had 10awg wire and plastic connectors, it started melting the connector.
Here's the kit millball used but in the auction it makes no mention of what gauge the wires are.
http://www.ebay.com/itm/HD-Head-Lamp-Headlight-Wiring-Harness-For-High-Wattage-Bulbs-9004-100-90w-Kit/400830393876?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140602152332%26meid%3Da6fa2afcd42440ecb2b3ca7974938778%26pid%3D100011%26prg%3D20140602152332%26rk%3D2%26rkt%3D10%26sd%3D331391850534
Old 02-25-2015 | 05:18 PM
  #25
bswarm's Avatar
I put some HELLA Vision Plus headlamps in a few weeks ago, they were a lot better but not quite as bright as I thought they should be. I checked for voltage drop from the battery to the headlamps and had a 0.4 volt drop on the positive terminals and 0.7 volt drop on the negative terminals. I installed this $22 HEADLIGHT RELAY WIRING HARNESS http://www.ebay.com/itm/330997592807 and immediately noticed an increase in brightness. I also replaced the speedometer lamps with some blue LEDs, looks cool.
Also, would like to see a wiring schematic for 1992 base 22RE headlamp system if anyone has it. I'm curious how the factory headlamps are wired. There is a factory headlamp relay in the underhood fusebox.
Old 02-26-2015 | 12:24 AM
  #26
Odin's Avatar
Did you check to see what actual voltage you were getting at the headlight with the stock harness Vs. the relay harness?
Old 02-26-2015 | 06:39 AM
  #27
bswarm's Avatar
No, I'll check it today and post results. I tested them out last night and they're most definitely better.
Anyone know the bulb size in the heater control for 1992?
Old 02-26-2015 | 08:22 AM
  #28
bswarm's Avatar
New harness/relay voltage drop test: Positive 0.23 V Negative 2 mV (0.002v)
Still looking for a bulb for the heater control, it's really small, like a Christmas tree mini bulb.
Old 02-26-2015 | 01:04 PM
  #29
Odin's Avatar
I meant total voltage, like 13.5V?
With my stock size battery POS & NEG cables cleaned and smeared with dielectric grease I get 14.48 at the battery. Using my stock harness and placing clips on the bulbs terminals my low beam is getting 13.07V.
I temporarily hooked up my Putco relay harness to see if it was going to work or not (it does) but I didn't check voltage because I didn't want to install it as a permanent item until I had made a couple of changes.
Old 02-26-2015 | 02:02 PM
  #30
bswarm's Avatar
It is 14.3 at the headlamp with it plugged in and turned on, it was 13.something on the old setup. Voltage drop is a much better test. Most of the drop was on the negative side with the stock setup, it's almost 0 with the new setup at the ground. I may swap the relays the kit came with for some solid state relays, it depends how long these last. The KYBs make for a rough ride and things tend to shake apart (like my old radiator did)
Also, the high beam indicator no longer works, don't really need it to remind me they're on anyway.
Old 02-26-2015 | 02:42 PM
  #31
Odin's Avatar
Voltage drop is definitely more accurate for testing the system. I was just curious what voltage you were getting at the bulb because it relates to lumen output.
At 14.3V you're driving those bulbs pretty damn good. Any thoughts of a higher wattage bulb?
Old 02-26-2015 | 03:05 PM
  #32
bswarm's Avatar
I will probably get a whiter bulb when these burn out but they're bright enough.
This is what I installed
http://www.amazon.com/gp/product/B0002M9QRE http://www.amazon.com/gp/product/B0002M9QRE
It came with 60/55W HB2 (9003) bulbs. Big difference over the stock H6054 sealed beams which were 65/35W.
I think I found the bulb for the heater control, bulb #74. Ordered a blue LED from Amazon that should fit.
  #33
Odin's Avatar
Solid state relays? Hmm, can't say I've heard of those before. Something to look into.
I've had KYB's on my 66 Nova and my El Camino. They are rougher riding than I like and I've had my fill of them. I'm either going with Bilstein or stock shocks.
Given your background you probably know the more vibrations and shaking the bulb experiences the shorter the lifespan. Sometimes the lenses aren't held securely by the retaining ring and they can vibrate and move around a little. Slightly bending the tabs on the retaining ring has always fixed it for me.
The high beam indicator doesn't work with my Putco harness either. As you've discovered it really isn't an issue though. Once you have good lenses and are driving the bulbs with good voltage you definitely know when the high beams are on. There is a thread on here where someone got a relay kit that had a resistor in it that allowed the indicator to work.
I think? it was a 9004 harness though.
Old 02-26-2015 | 03:27 PM
  #34
millball's Avatar
One common type of solid state relay is a thyristor.
Old 02-26-2015 | 03:46 PM
  #35
bswarm's Avatar
The high beam indicator doesn't work with my Putco harness either. As you've discovered it really isn't an issue though. Once you have good lenses and are driving the bulbs good you definitely know when the high beams are on. There is a thread on here where someone got a relay kit that had a resistor in it that allowed the indicator to work. I think? it was a 9004 harness though.
I'm doing LEDs for all but headlamps and reverse. I'm thinking a small bulb in the unused headlamp socket might bring back the highbeam indicator, still have to investigate that, but it's not important to me. The KYBs are pretty harsh, but I'm used to them. Definitely takes corners good, drift cornering included.
Old 02-26-2015 | 03:48 PM
  #36
Odin's Avatar
Aaaaand I think it was millball who purchased that relay kit.
I find the makers are listed on ebay as Sun Shine, Sunshine, or California Sunshine.
Old 02-26-2015 | 04:06 PM
  #37
bswarm's Avatar
BTW, the wiring harness I got was listed for 6024 headlamps. It's the same kit as the one for 6054. They are all the same 3-prong connector and $20 cheaper if you look around ebay.
Old 02-26-2015 | 04:34 PM
  #38
Odin's Avatar
That harness only has one fuse. If it pops no low or high beam?
Don't know if I'd like that. Adding two fuses is one of the thing's I'm doing to the Putco harness.
Old 02-26-2015 | 04:57 PM
  #39
bswarm's Avatar
I looked at the Putco ones, I didn't even see a fuse on them, that looked dangerous. I carry spare fuses, and even if the relay went out, I could just plug the stock connectors back onto the headlamps.
The following users liked this post:
QuiGonJon (01-09-2021)
Old 02-26-2015 | 10:27 PM
  #40
Odin's Avatar
Exactly. It would be quite easy to add one fuse but I'd rather have two.
