Electrical- lights
Electrical- lights
Electrical- lights
I have a 1989 Pick up 4-cyl 4WD 5-spd. I have electrical problems with the lighting system. I have headlights but no running lights. Brake lights work and so do hazard and turn signals. Just no running lights? Any help would be great I am new I hope this is the right place to post this question. Many thanks in advance-
Eden
Eden
Electrical- lights
Thanks Elton for the quick response! I pulled them and they looked fine. I will pull them all again at the driver side left foot kick panel. I will check them for continuty with my meter. I also purchased a new headlight switch $55 from the parts store under their direction. I have taken the steering wheel off to get at the switch and the wiring harness. After carefully taking everything apart (especiallt the pins that are socketed into the wiring harness) and installing the new switch I am at the place I started. Everything except the running/parking lights-
many thanks again,
Eden
many thanks again,
Eden
Electrical- lights
NO DASH lights either sorry. I have installed several things. Cig lighter for 12v power and a brake light kit for a trailer. The brake light kit is the no splice no fuss kind where the kactory brake light pig tails coupl into this new harness and the new harness provides trailer leads. The trailer light kit was 2 years ago at least though? Cig lighter was last December when I got Sirius.
Thanks,
Eden
Thanks,
Eden
Sounds just like what i experienced tonight, gonna try to check things out tomorrow, will come back to post if i can help.
My problem has to do with blowing fuses repeatedly. The tail light fuse blows after like 5 secs of having the lights on. Guessing it's a short, so we'll see.
ashersullivan88yota
01-18-2022 05:37 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
