Cranks no start !!!???
92 4Runner 3.4 5 speed.
I kinda new going in what the issue is!!
Parked the vehicle Thorsday Morning @ 0900 give or take.
All was well.
This morning go to leave cranks no start.
First thing I did was pull any codes Nada
Now I pulled off and cleaned all the ground cables because it is easy !!
I might have been lucky no such luck .
Meter check the important fuses and relays Manage to break the EFI Relay #90987-02010 if anyone has one laying around I think the starter relay for that year will also work .
Because of the way the pins are laid out I can change the socket if need be.All the ones I have the pattern is different .
Looks like real hack wiring but it is working.
I found the Circuit Opening Relay had the water in it freeze from the fast drop in temperature.
Basic Electrical Common Sense if you mounting things install things with the plugs down or a least Horizontal unless they are weather proof connectors
Good thing The older COR`s are the same if anyone does not know now you do.
Different part # but electrically the same as Toyota is known to do.
All was well.
I would never speak ill of the Banned ( Well maybe) but it seems like the part # I quoted comes back as a Fog light relay.
it did work right up till I broke it.
Seems like the Rear Defroster and the Sun Roof relay may swap as well.
No telling what interesting things I keep finding!!
Mike hayward
10-28-2015 10:24 AM
CajunFisherman
10-17-2015 06:12 PM
