General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Old 03-11-2016, 03:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problems by Symptom
Print Wikipost
Battery not charging alternator is good.
Old 09-07-2011 | 09:59 AM
dawa88's Avatar
Id also like to point out, if its helpful, that the alternator warning light doesnt come on when i turn the key and hasnt since the original alternator.
Old 04-01-2014 | 05:03 PM
larryb936's Avatar
it may be a rely or the cpu
Old 04-01-2014 | 05:35 PM
larryb936's Avatar
2006 Tocoma
I have a 2006 tocoma the Alternater not Chaging rite i whent to a alternater shop tested the alternater out of the truck tested good tested the four wire plug with key on IGN 12.50v s 12.50v L11.50v FR 11.05v thay said FR shod BE zero Voilts Changed junction block din't fix it HELP
Old 04-01-2014 | 07:44 PM
dawa88's Avatar
Mine turned out to be a loose fuse box behind the kick panel. Might be worth starting up a new thread though, given that doesn't sound exactly like the issue I was having initially.
Old 11-09-2017 | 04:16 PM
  #25
Donnieboy747's Avatar
To trick440
Originally Posted by Trick440
OMg, it was a fuse inside the cab. The actual fuse is good but its loose and is making a bad connection.
So... PROBLEM FIXED!
Gday mate, I've had the same sort of problems, ie battery not charging, swapped out 2 alternators and batteries etc. Just wanted to know which fuse it was and where it was at all pls? I have an eb 91 falcon and realise that fuse will be in a different area but any information would help me out a whole lot. Many thanks in advance, donnieboy. Cheers.
Old 11-09-2017 | 07:38 PM
  #26
RAD4Runner's Avatar
Alternator troubleshooting needs to be posted on threads specific to the model-year-ENGINE. Each model-year-engine may have same concepts and alternator pin-outs: Ig, Sense, L (fault), B (alt to batt wire)
However, schematics vary. For 22RE-liable, here's how charging system works:
https://www.yotatech.com/forums/f199...l#post52094780
Old 11-09-2017 | 10:52 PM
  #27
dawa88's Avatar
Hey, sorry its been a good few years since i had to tackle this issue, so my memory is a little hazzy. What i do remember is that I was not able to pinpoint a specific fuse that caused the issue. I gather the issue was a loose connection at the back of the fuse box (in my case the box behind the drivers side kick panel). In unbolting the box and reinstalling it the faulty connection must have remedied itself. Sorry i dont have anymore information regarding it. Best of luck, i know how frustrating it can be.
Old 04-06-2018 | 04:50 AM
  #28
Stevenmolljd's Avatar
Not charging with good alternator
Hi guys.
My battery isn't charging. I assumed it was the alternator but I pulled it and had it tested. It tested fine. Just to be on the safe side I bought a new alternator anyways.
I installed the new alternator and it doesn't seem to be working.
I'm testing at the battery and get 12.5v with the truck off. I turn the truck on expecting 14.5v, but it stays right around 12.5.
This is a 1990 Hilux, 22re 4cyl., the voltage regulator is in the alternator (i think) so that shouldn't be the problem.
I started to check all the basic connections and they look good. So I don't know. Thats why I'm here.
Any help please?
I know its not the same vehicle but I
had the same problem on a 2003 toyota corolla.
Are your guages on the dash working. This
vehicle they were not. Found thr fuse for thr
guages was blown. Replaced fist and tge
alternator started pitting out just over 14 volts.
Hope its as easy as that.
good luck.
SubiKing
08-21-2021 03:57 AM
Peevedkitten
11
08-31-2015 06:57 PM
bvleonov
08-22-2015 11:39 PM
izzmee
08-17-2015 10:20 AM
80Truck
07-24-2015 03:12 PM
Quick Reply: Battery not charging alternator is good.
