94 toyota pickup ac compressor ground wire help
I removed my ac from my 94 toyota pickup and i wanted to know if i can remove the ac compressor ground wire or does it to to be mounted somewhere
Thats not the AC ground wire, it's the main battery to engine ground.
It must be solidly connected to the engine block
Make sure that everything is clean and shiny, and bolt it back to the engine near where you found it fastened before. You may have to find a shorter bolt than what was used with the AC compressor fastening.
mbomberz1
04-29-2023 09:58 AM
FS[WestCanada]: 1988 Sas'd toyota pickup
RoadRage
10-09-2015 07:43 PM
