who has the most miles?
#41
Well Im #3 at
248,200 on my '90, 3vze...
Some water attacked my 3rd gear clutch plate and valve body, hence no more reverse tire chirps...
But beyond that, doing good.
Steve
Steve
#42
Originally Posted by Beachrunner
and i thought 132K on my 97 was bad... makes me feel better.
#45
My girlfriend has a 93 corolla with 285,000 on it all original (except radiator). The tranny is starting to slip so she is looking into a newer corolla.
I have a 97 4runner v6 w/ 83k
#48
Here are all of the 4runners in my family:
dad: '85 4runner 22RE about 225,000
mom: '91 4runner 22RE about 395,000
mine: '91 4Runner 3vze about 202,000
brother: '93 4runner 3vze about 175,000
brother: '86 4Runner(was mine) about 260,000
....pretty good record
#50
I have 1990 2.4 4cylinder with a 5 speed tranny and 289,987 miles on it. Although the engine has never had anything more than routine maintenance on it, I am facing the decision as to what to do with tengine as the compression is slowly, b ut steadily dropping fromthe #2 cylinder. Not too shabby, eh? I also have a 1983 Tercel that has 342,5256 miles and the engine will probably outlast the car! You gotta love those Toyotas.
#53
my 98 4runner has 86k 3.4......the 86 4runner has 210k 2.4 22re and its still running strong...im hoping it will last a lot longer. im sure it will toyotas will run until the body falls off
amy
amy
#55
197,000 miles on 85 22RE
Thats 20 years of michigan winters. Recent timing chain and engine seals. The only issue I have is everything that attaches to the engine, haha. Sensors and whatnot can be tough to figure out, but engine/trans/tcase all really strong.
#57
How often did you change oil and filter and did you use synthetic?
If you're asking me, mostly i change the oil and the filter every 3,000 miles, but there have been several times that I went over. A few times I even doubled it, and I just used castrol gtx
#58
I have @ 276,000 on my 93 SR5 and it's still running strong. Only problem is that she seizes fan clutches. Seized my 4th one about a month ago and have since solved the problem by going to an electric fan with auto thermostat.
