Toyota's 5.7 Liter i-Force Cooling.
1 Post
So they had a 5.7 Liter i-Force apart on an engine stand at the local dealership a family member of mine works at. The just of it was it's an American truck brought up here so there is the American/Canadian Toyota warranty thing (Toyota is one of the only companies that honours warranties for people that cross the border apparently from what I've seen/heard). The just of it was they could tell someone had tried to do some work/mod/play with it, who knows what, and it caused some bent rods on the engine and a few other parts to go. So they have the thing apart on an engine stand right now and I got to take a look at it yesterday.
I wish I had a camera. You guys would shat yourself at the cooling jacket around the cylinders. It literally makes the cylinder sleeves look like they are isolated and there is a "moat" around them there is such a big cooling jacket.
probably looks a lot like most open deck blocks ....
that's a honda block for example, most aluminum blocks are similar. Search "open deck" in google images, for more examples.
yeah, that's an open-deck block design. Better for cooling, but the bores can shift under extreme loads. That's why a lot of the honda guys who are revving them realy high, or running a lot of boost through their open-deck motors either tap some studs into the block to hold them still, or fill them with a concrete like solution with the same thermal expansion properties as the block.
1 Post
You see the clearances between the sleeves and the block in that picture on that Honda block? Well the Tundra's if I recall correctly are at least 50% more then that.
09-04-2015 09:27 AM
