removing elocker connector-help!
Old 01-16-2006 | 05:12 PM
Hornito's Avatar
Hi,
I'm removing the third member from a tacoma trd and I can't get the pass. side connector off of the elocker actuator. It is square gray plastic and I don't see a tab on it. Sorry I don't have a digital camera. Also, I didn't lock my locker before removing the third; Do I need to lock it or can it be locked manually once I remove it? Thanks!
Hornito
Old 01-16-2006 | 07:15 PM
ecchamberlin's Avatar
bump to get this guy some help.
Old 01-16-2006 | 07:47 PM
Hornito's Avatar
I've been futzing with this for hours now must be seized on there?
Old 01-16-2006 | 09:00 PM
Jake94's Avatar
Look close again, IIRC there is a tab that needs to be un clipped. The connector has an "O" ring seal and has a dab of grease from the factory, makes for a tight suction fit.
No worries on removing the 3rd unlocked, you might have to lock it to get it back in, some times the locking collar likes to get hung up on the axle housing, makes it a bear when trying to hold it up and get it lined up
Old 01-16-2006 | 09:29 PM
Hornito's Avatar
Thanks guys. I finally got the connector off; the tab is underneath and difficult to see. So you can manually lock the locker before reinstalling it?
Old 01-16-2006 | 09:40 PM
Jake94's Avatar
yea, just pull the actuator off and you can move the shift fork by hand. Just keep track of which position the shift fork, actuator and the switch are in when you reasssemble.
Old 01-16-2006 | 09:51 PM
Hornito's Avatar
Do I need to remove the actuator before pulling out the third?
Old 01-17-2006 | 06:11 AM
Doc279's Avatar
Got a question.
Does anybody sell a manual cable for the e-locker third ?
I am planning on adding the e-locker and would prefer to operate it by cable
instead of the inch worm wiring kit.
Old 01-17-2006 | 11:40 AM
tc's Avatar
tc
https://www.yotatech.com/forums/f116/e-locker-2nd-generation-75897/
Old 01-17-2006 | 12:21 PM
Doc279's Avatar
Thanks - I'll be contacting Downey.
Easier to ask than search sometimes - especially from work.
1uzRunner
63
11-10-2018 03:58 PM
Anthony Lee Mathis
09-15-2015 07:22 AM
LotOMiles
09-14-2015 11:45 PM
Rickstwowheels
09-09-2015 06:12 PM
gp66
09-07-2015 08:29 AM
Quick Reply: removing elocker connector-help!
