Links to Factory Service Manuals part numbers
*Mod Edit* Hey all, I cleaned this thread up a little since it expanded from FSM (Factory Service Manuals) to links for anything Toyota! A huge thank you to CyMon for starting this thread. Also I deleted some of the posts that were just chit chat so it is easier to find the links you need. Lastly I moved this to general tech since these links cover all Toyota's and not just the 85-90 specific ones. Thanks! -Molly
this is a link for Field shop manual,FSM ,factory service manual what ever you want to call it this is not a haynes or chiltons this is the real deal. it is in PDF file.
for 4runners and trucks of many years I think there are more links on some of the other pages on that first thread.
http://www.4x4wire.com/forums/showfl...5&o=14&fpart=1
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
member Toyotero posted up this but it looks like it got passed up so I am linking it here
https://www.yotatech.com/forums/f115.../#post50938942
this link is for 85 through 2005 trucks and 4runners there are 5 or 6 manuals to choose from
http://www.ncttora.com/fsm/index.html
and heres a list of part numbers for 80's trucks and 4runners.
Last edited by CyMoN; 02-19-2009 at 05:07 PM. Reason: changed the title so people will know it is for the the factory manual instead of it saying FSM
Stickied!!!!
And here are more realevant links:
As well as this one from Mike Ross
http://sn4wd.com/~mike/357/
More good FREE links! (A lot of this I took from my CoTTORA thread - "Reasearch Links For Toyota Gear Heads"
http://www.ttora.com/forum/showthread.php?t=82481
http://www.4x4wire.com/toyota/mainte...nd/solid_axle/
http://www.4x4wire.com/toyota/mainte...d/hub_rebuild/
http://forum.ih8mud.com/79-95-toyota...b-rebuild.html
http://www.off-road.com/offroad/arti....jsp?id=399668
http://www.gsp9700.com/pub/search/findgsp9700.cfm
Here are the few I have gleaned from Troy... (Troy feel free to edit this post with better descriptions that I have given!)
* http://www.bobistheoilguy.com/ - Everything you wanted to know about Motor Oils and lubricants.
* http://www.4crawler.com/4x4/index.shtml#top - 4Crawler's 4x4 Information - This site is a wealth of Toyota Info!!! (He also sells parts new and used)
* http://www.4x4wire.com/toyota/? If you can't find it... look here... an extensive list of how to for toyota. You name it - they cover it.
* http://www.ttora.com/wiki/index.php/Main_Page The OFFICIAL TTORA FAQ and Knowledge base....
* https://www.yotatech.com/wiki/index.php/Main_Page The Yotatech Wiki. Well established and a lot of info there.
* http://www.ultimateyota.com/index.ph...=40&Itemid=137 This is the UltimateYota Wiki. The site is young so not too much there, but there are some knowledgable peeps there, so check it out. You do need to register in order to view the forum.
* Not a URL but a worthy thread about onboard air: http://www.ttora.com/forum/showthread.php?t=82448
More from Troy:
And from a buddy on TTORA
FSM for '93 Pickup
Differential Info thread (includes link to how to mod preTaco housing for elocker)
http://home.4x4wire.com/erik/diffs/
Link suspension design
http://www.avalancheengineering.com/july2003.htm
If I can post here, heres a link to lots of links http://mywebpages.comcast.net/jonmar....htm#bodyparts
www.gadgetonline.com
Great articles, experiments on K&N, deckplate mods, FIPKs, etc, and actual dyno tests to prove the data.
FSM for '93 Pickup
Suspension mods for the IFS - Only Coil overs, bump stops and leafs.
Hidey-ho, neighbor and anyone looking to do a lift is to ask these simple questions.
1) How much are you willing to spend
2) What type of off roading are you going to do
3) What type of driver are you
4) Is your truck a DD or trailer rig
5) Do you plan to haul stuff and how much
6) Did your wife/gf approve the purchase
Use these links below to read and understand....
CustomTaco's only piece of good info for off roaders.
Parks Offroad.com-installation and opinions
Body Lifts - answers by 4crawler.com
Lift - - the question - click here.
LEaf spring opinion poll.
Cams vs Hoes - mandatory reading
Toyota.off-road.com CO-Shock comparision
Downey-Off Road, CLick on to Suspension then the model year of your truck
UCA information
Shackle's anyone? - click here.
Shackle's anyone part II? - click here.
Timbren Bump Stops - click here.
That should be it...but to read, learn, listen and if possible, ride with some guys that have different systems to see how they like it and how it handles.
Good Luck!
UCA information
Good Luck!
www.gearinstalls.com - This guy walks you through toyota gear installs with pics and everything
www.sonoransteel.com - Info on a bunch of mods, e-locker retrofit, arb install, marlin dual case install etc on a 3rd gen 4runner.
www.larsdennert.com - home made rock sliders with air tank capability and other mods.
http://www.precisiongear.com/pgtechpatterns.htm - gear contact patterns
http://www.traildamage.com/ - Trail descriptions, I don't think you were asking for this Molly, but here ya go!
http://bushducks.com/tripreps/passopen.htm - Trail opening dates for Colorado, see the previous year descriptions from other offroad enthusiasts. Again, I don't think you were asking for this...
added a new link http://www.ncttora.com/fsm/index.html
93 FSM manual iso
Hey everyone, I hope I'm not stepping on anyones toes here, but if so please let me know.
I liked the idea of the online 93 fsm, but fear that the site may go down eventually prompted me to find a way to save it.
I copied the site to my hard drive and made an ".iso" file that you can download and burn to cd.
You should be able to right click the file after downloading it,...and burn the iso image with whatever cd / dvd burning software you have installed.
It has an "autorun" feature that should automatcally bring up the index page when the cd is inserted after burning.
Unless your pc has 'autorun' disabled, if so heres a link to explain how to re-enable it.
http://www.moonvalley.com/products/rwavdc/enable.htm
I have included a folder on the cd iso which contains Adobe Reader 8, in case it is needed on your pc to view the pdf's.
The .iso is roughly 59MB and I didn't have any space that large to host the file so I registered with a new free site that offers 2GB.
I had to use winzip to package the .iso since the file hosting space wouldn't allow hosting of .iso's. Hopefully this will work.
Heres the link to the zipped .iso:
http://www.snapdrive.net/files/502119/93%20SERVICE%20MANUAL.zip
Heres a cheesy cd jewel file made with Roxio.
http://www.snapdrive.net/files/502119/1993%20Toyota%20Truck%20%26%204Runner%20Manual.zip
This first link doesn't work.
I'm trying to find a manual for my 79'
ATTN: Mistake in '93 FSM....A BIG ONE!
http://personal.utulsa.edu/~nathan-b...34electron.pdf
I think for everyone that would be concerned, it should be known that on pg. AT-131 the procedure for the testing of, description of, and location of the #2 speed sensor on (atleast) the A340H transmission is incorrect.
See post #45:
https://www.yotatech.com/forums/f116...l#post50760850
See post #45:
I've found this site to be helpful; http://www.autoshop101.com/
Currently, I've been reading about this.....a prime example:
http://www.autoshop101.com/forms/h21.pdf
file not found.... sadness...
I have a pretty phenominal TOY FAQ (10 MG) that I got by donating 25 bones to Pirate through The Friends Of The Rubicon. It's incredibly thourough, thoug I can't easily post it or send it (10 MB remember) And I wouldn't want to bypass the reason I got it which was by donating to FOTR on Pirate, but if ya really need it PM me and I'll see how I can get it to you...
Just to jump in and deviate from that slightly, (and going into complete cadging mode), if anyone does ever happen to have a digital copy of a manual which I haven't already got up on the site that they wouldn't mind sharing, I'm always looking for new additions.
Matt I have a wonderful Toyota FAQ I got from Pirate but they ask that those who need it send $5 to a charity I think Friends of The Rubicon in CA. At any rate I would be willing to give you some teaser stuff from it and then if anyone wants the whole thing they can buy it. Would that be ok?
