Leaking gas tank tips?
Hi I have a 85 toyo truck with a leaking gas tank. It leaks from the spot welds where the baffles are welded on the bottom. I have used some two color putty for gas tanks but it still leaks. The leak is small no drips just enough to evaporate. Any tips would be appreciated. Thanks
Might try sealing the tank from the inside:
- http://www.por15.com/prodinfo.asp?grp=TS&dept=12
Or get a used one to replace yours.
skoti89
09-11-2015 07:46 AM
pyramid
07-30-2015 10:05 AM
