fluctuating idle
fluctuating idle
Hey guys,
This has been a problem on my runner for som time and I have change a multitude of parts in search of the answer. My truck idles @ 1200 rpm and I cannot turn it down, sometimes after driving, at lights it won't come down past 2000 rpm and I have to put it in 3rd and ride the clutch a it to get it to return to 12-1400. If I have drivin for a good distance and shut the truck off, upon restarting it will idle at 800 rpm until I start driving again. That is it any help would be great.
I have a new o2 sensor, k&N filter, plugs, cap rotor, wires,
Thanks
Thanks
I would clean the IAC (idle air control). Do this off the truck, I think you can mess up your TPS (throttle position sensor) if not. Then set your idle to the proper RPM and then check your timing.
it turns out it was the spring loaded throtle stablizer, kept sticking, i took it out and the idle is great. Will have a post when my rebuild is done next week
thanks
thanks
Blamalam
03-12-2022 07:34 AM
noosh
08-21-2015 03:49 AM
