Driveline Shifted!!!
I got a little air born this past weekend and my stick shifts shifted over about 3 or 4 inches so I got under the truck and it looks like the mount that holds the transfer case has issues now.. there are 2 rubber mounts that hold up the transfer case in place and one is kind of torn and shifted over.. what do yall think the issue is before I start tearing things apart??
Chances are you torqued the transmission loose on landing, get new mounts because you need them anyway. Its not a terribly difficult job to replace em and you can go from there to see if there are any other problems.
Probably a good idea to check the frame and crossmember for any warp also.
punks_is_4x4
02-26-2016 04:29 PM
Odin
09-26-2015 06:56 PM
