Do you use oil between changes?
I switched to synthetic engine oil when I bought the truck about 20K miles ago. I've noticed that my oil level is low about a quart and a half between changes.
No leaks.
How many of you experience this? I've got 110K miles now.
No oil in coolant.
uberhahn
No leaks.
No oil in coolant.
uberhahn
its not totally uncommon to get some oil consumption on a motor with more miles on it, but a quart and a half are ridiculous. how often do u change your oil, your positive you dont have a leak?, and remember, your oil filter can hold a decent amount of oil in it, so attribute some to that.
its common for oil to be burned when you switch to synthetic oil on a high mileage engine that has always had regular oil in it. its blow by on the piston rings. no worries. your good to go.
When you change your oil do you run it for a few minutes and recheck it?
You should never let it get that low.......
I switched my 92 to synthetic at 150K, doesnt burn more than 1/4 qt per 2500 miles...
Toyvana
07-29-2015 10:47 PM
yourrealdad
07-29-2015 11:08 AM
