4WD engagement issues
Old 12-29-2011 | 12:13 PM
Witchgrass's Avatar
Ive been reading thru the stickys and been 'searching' this topic for a week, but I still don't get it! 4runner is a 95, 3.0, 5 speed. When the shifter is put in 4H, the dash light comes on (between 2h and 4h) then goes off. Front wheels don not engage. With a friend helping, I put it in 4H, he then pulled the vacuum line (at the accuator on front diff) fron drivers side. He said it had a good vacuum at the hose. While this hose was off, the green 4WD dash light came on and stayed on. I was not able to jack it up or drive to see if it really was engaging. When he put the hose back on, the light went off. Any ideas what this means? Was it really engaged. When I get home this evening, I can jack it up , pull the hose and serif it is engaging. Thanks for any ideas.
Old 12-29-2011 | 02:07 PM
calcuta's Avatar
I had the same problem on the transfer case there is a wire hookup that tells the actulater its in four wheel drive mine had come unhooked
Old 12-29-2011 | 02:23 PM
Witchgrass's Avatar
My wires still appear to be connected. The only thing that changed was: the 4wd light in the dash came on when the drivers side vaccum hose was removed from the accuator.
Old 12-29-2011 | 03:02 PM
RAWRMON's Avatar
Well i have a 95 withe a 22re.. i had to switch my vac lines and bam it works now.. and very well. find a hill and try to climb it.. always works for me
Old 12-29-2011 | 04:56 PM
Witchgrass's Avatar
I think I will remove the accuator this weekend to see if the fork is still moving on the little rod. It may just be stuck from not being used? It's worth a try.
Old 12-29-2011 | 05:52 PM
justin_4runner's Avatar
so with one side of the vacuum lines off the actuator it then shows its in 4wd? it sounds like u have the vacuum lines on the wrong side. up on the fire wall on the passanger side take and switch them and then try it, hope that works if not then it could be a bad actuator.
Old 12-29-2011 | 06:05 PM
Witchgrass's Avatar
It's possible they were switched. I just got this truck. The engine was rebuilt by a guy of questionable ability. So it would not surprise me if these were switched. I will try this tomorrow and report back. Thanks for the advice.
Old 12-30-2011 | 12:07 PM
Witchgrass's Avatar
I switched the vacuum lines. We now have full power(4wd) Captain! Just my luck, the last of the mud holes just dried up too. Thanks again guys.
Old 12-30-2011 | 12:45 PM
good to hear, now go make your own mud area and have some fun...
mskalmus
05-28-2017 07:51 AM
adammtb
07-27-2015 11:57 AM
jgwerth
07-16-2015 03:23 PM
TokyoD23
07-12-2015 06:01 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 4WD engagement issues
