22R timing chain knock or rod?
Old 01-02-2016 | 08:16 PM
BlackStone's Avatar
Installed powersteering on my 4runners swapped 22R, sounded fine yesterday before the swap. Could it be the pulley that I installed today being out of alignment?
Went to fire it up today and......
http://sendvid.com/o1vw9ile
Looks a little cock-eyed? Space on top- zero, bottom looks like it has a tiny bit.
Old 01-02-2016 | 08:28 PM
millball's Avatar
Well, its a no-brainer.
Take the belt off and fire it up.
You'll know instantly.
Old 01-02-2016 | 09:53 PM
BlackStone's Avatar
Touché sir! First thing tomorrow. Was curious if anyone could diagnose the problem, if it were a big issue. Thank you for the response, I'll update tomorrow
Old 01-05-2016 | 07:55 AM
kawazx636's Avatar
Staff
You could have air in the system. Air in the fluid doesn't typically sound like that, but it could be your issue. Did you bleed the power steering pump before you started it? You should have turned the wheel from lock to lock several times and topped off the fluid before you started it. Also, you should be using Automatic Transmission Fluid - NOT power steering fluid.
Old 01-06-2016 | 06:39 PM
millball's Avatar
Anything new to report on this??
Old 01-06-2016 | 08:00 PM
BlackStone's Avatar
Thanks for the replies! Fortunately it was just the bolts on the pulley that backed out, causing the rattling. I put loctite on them and all seems to be good now. Very relieved that it want something serious, as it is due for the Timing chain overhaul. Which was just ordered from Engnbldr, in a panic it might have been that.
http://sendvid.com/01dyy9od
Old 01-06-2016 | 09:51 PM
millball's Avatar
Thanks for the report!
PBRaddict#1
11-13-2015 09:28 PM
95_n130
11-13-2015 07:46 AM
Brandon H.
11-01-2015 07:07 PM
mct75
11-01-2015 07:42 AM
ET
10-22-2015 02:37 AM
