vacuum problem 3.0
vacuum problem 3.0
im not getting vacuum to my egr valve so i was checking for leaks when i noticed the 3 ports on the throttle body and the 2 that go to the egr modulator and egr have no vacuum are they supposed to its a 1990 toyota 4 runner 3.0 v6
Check the green VSV valve on the passenger fender, This is over look alot.
The VSV can sometimes get water in it and rust or plug.
The route the vacuum follows is,, 2 lines from the throttlebody to the EGR modulator (Note a Fat hose from the EGR exhaust tube connecting under the ERG modulator)
Then fro the EGR modulator to a hard tube going under the upper plenum then comes out and connects to the GREEN VSV.
Then from the GREEN VSV back to a hard tube going back under the upper plenum and out right next to the EGR valve.
TokyoD23
07-12-2015 06:01 AM
