upper and lower control arm bushings
I am new so please bear with me. I have a new set of bushings to put in a bare set of control arms. The bolts look to be quite a bit smaller than the i.d. of the bushings. Is there a inner sleeve that goes between the bolt and the bushing? I am starting with a bare frame so I don't have a set to go off of. Truck is a 93 ext cab 4x4. Thanks
Yes, the upper and lower bushings have inner and outer sleaves. The lowers also have washers/ferrules at each end.
Lower bushing.
Upper bushings.
Lower bushing.
Upper bushings.
Thank you so much. I came upon a 93 totally ripped down to the frame, so I just don't have the tear down experience to tell me some of the things. So far it has been quite fun trying to figure out where everything goes. Fsm is great for parts, but its the bolt search that can get you scratching your head! I am sure I will be asking many more questions!
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
kirkrunner
07-27-2015 07:59 PM
FS[SouthCent]: TX Third Gen UCA and LCA low miles Taco
KyleT
07-21-2015 07:54 PM
