Now leaking oil *sigh*
Old 07-17-2012 | 09:31 PM
solidaxle85's Avatar
Hey guys so last weekend my truck randomly had low oil which I didn't even knew it lost oil I checked every two weeks and it seemed fine but when we were camping I started my truck and let it idle for a but while I tightened everything and I looked at my oil pressure switch and it was pouring out due to low oil so. Luckily I had a filter and a couple qaurts of oil changed on the spot topped up good to go. Now there is a leak from the back ofy engine doesn't leak much but I was wondering what that could be?
Old 07-17-2012 | 09:53 PM
Gebee00's Avatar
what motor we dealing with here?
Old 07-17-2012 | 10:04 PM
87 Deathtrap's Avatar
With a username like "Solidaxle85", I think we're safe to assume it's a 22r/re. With a leak at the rear of the engine it could potentially be a bad valve cover gasket leaking down the backside (easy fix), an oil pan gasket (easy fix with a solid axle), or a rear main seal (not quite as easy). Start by cleaning off all of the residual oil and keep a close eye on it.
Old 07-17-2012 | 10:18 PM
It is a 22re 86 my dad had a 85 solid axel when I was young
Old 07-17-2012 | 10:48 PM
Well, of course it is. No more assuming specs based on usernames for me.
Being IFS, the oil pan gasket is a little more involved but still doable with basic tools.
Old 07-21-2012 | 09:03 PM
Yeah valve cover didnt work, replaced it and the half moons started it didnt leak, went for a drive didnt leak. Then went to go grab a box 200km out of town and i almost ran out of oil and there was oil oil on my chasis.
Old 07-27-2012 | 10:25 AM
rubiconrunnerneville's Avatar
rear main seal maybe?
Old 07-27-2012 | 10:49 AM
Philbert's Avatar
My guess is rear main, since it's leaking so much so fast. If it were teh oil pan in the back I'd imagine it would leak slower, since the majority of the oil is in the bottom of the pan and not resting against the gasket seal.
Try this: pop off the rubber boot on your clutch fork (you may need to unbolt the slave cylinder to get access). Then shine a light in there toward the engine/clutch and see if there is oil all over the place...if so, it's your rear main seal and you'll need to pull the transmission to fix it. You could also take a pinkie and rub inside that hole to see if you pick up any oil. That bellhousing area where your clutch mates up should be DRY....if it's not, this is your issue most likely.
GL!
Old 07-27-2012 | 05:29 PM
Well to philbert, it only really happens when i drive for a bit, it can leak then stop, then when i start it up i can go for a bit and park it and it wont leak but if i go for a drive it starts to leak..So that could probably still be my rear main ?
jasonty
41
12-23-2018 01:00 PM
Ladythump
22
11-09-2015 08:53 AM
yourrealdad
07-21-2015 11:13 AM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Now leaking oil *sigh*
