No headlights!!!!
No headlights!!!!
I have to go to work on Monday, so I need this fixed ASAP. My alternator went out Christmas eve so I bought a new one and replaced it. 3 nights ago my wife and I were going down a gravel road when my lights just went out. Drove it home and found a blown headlight fuse (i guess it's a headlight fuse, pic posted below) replaced the fuse but nothing. I bought a used relay and replaced that but still no lights. I checked the fuse again it was blown again. Now every time I put in a new fuse it blows. What my problem?! The fuse that blows is at the bottom right (the empty slot at the bottom right)
Lower right fuse it typically the Haz-Horn fuse:
- http://www.4crawler.com/4x4/4R_TechI...tml#Electrical
The middle two are the right and left side headlights.
- http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
If it is the Hazard-Horn fuse that is blowing, then it has nothing to do w/ the headlights. The headlight fuses would only kill one headlight or the other if one fuse blew out. Any chance of a trailer wiring plug on the truck? If so, not uncommon for those to cause problems, that fuse also works the turn signals.
Might check the headlight combo (dimmer) switch:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
alright, my trck is at my father-inlaws bc he loaned me his car last night. As soon as I go over there in gonna disconnect it. Thanks man I'll let you know what happens.
I had a friend look at my problem and used a tester and said their not getting power. Im going to have to buy a new switch I guess. Or try to clean of the contacts on the switch
Where exactly was this voltage test done? If at the headlight connectors, you'll normally only see power (12 volts) at the common terminal. That voltage comes from the headlight relay via the left and right headlight fuses. Then the headlight dimmer switch provides the ground connection (0 volts so you will never measure any voltage on those terminals). So if you are missing the 12 volts, suspect the relay or fuses or wiring between those parts. If missing the ground connection, then suspect the wiring or headlight dimmer switch or the cab ground connection.
kawazx636
10-06-2021 03:03 PM
