Sponsored by: CARiD
need shock advice fast
Old 08-12-2006 | 02:07 PM
jeremystephens's Avatar
96 runner ltd
3" suspension lift
1" BL
will stock length shocks work
if not what length will i need
Old 08-12-2006 | 02:13 PM
Firefightertaco's Avatar
They should work for a while if u dont do any wheelin, but there gona be way to short.
Old 08-12-2006 | 04:20 PM
im 95% daily driver
5% off road but not too serious
Old 08-12-2006 | 04:23 PM
User 051420's Avatar
I see you're new here, and I'll point you in the right direction.
First, hit the search button up top and that'll help you figure out which lift you want, and how it's done.
Second, here's our fantasitc Lift FAQ..... https://www.yotatech.com/forums/f31/suspension-lift-faq-44741/
It helps to help yourself.
Old 08-12-2006 | 07:57 PM
i already have the lifts
3" toytec suspension
1" custom bl
i just need to know what length shocks to get
or will stockers work
Old 08-12-2006 | 08:46 PM
kwight's Avatar
1" custom bl
Disconnect your stock shocks. Cycle your suspension by ramping the truck on an incline or using a floor jack to find your full compression. Take a measurement of this. Next check the other side which should be at full droop. Take measurements both front and rear. When you are done, take those measurements to your off-road store and have them order the shocks that will allow that much compression/droop.
Kevin
he's gone
7
12-03-2019 08:08 AM
punks_is_4x4
08-21-2015 02:35 PM
Dennisx2
08-10-2015 07:48 AM
Dennisx2
08-04-2015 02:26 PM
SMOD
07-27-2015 02:45 PM
