Sponsored by: CARiD
Max tire size that will fit under 1996 Tacoma?
Old 05-13-2006 | 04:57 PM
SuaveGato's Avatar
Question Max tire size that will fit under 1996 Tacoma?
Hello,
I have recently acquired a new (to me) Toyota truck and am going to be doing some mods. to it. Before I do however, I am going to be making numerous posts looking for some help, information, opinions, advice etc. Any and all input is greatly appreciated, thank you! Vitals: 1996 Tacoma, 4x4, X-cab, 3.4L V6, 5 spd.)
I am building this truck as general hunting vehicle. I will not be rock crawling or “Bajaing” it… I just want something that will do some good wheeling and or mudding to get me safely in & out of my favorite hunting spots.
Since it will be 90% for off road, I need to get some off road tires on it first. I’d like to put some 33 inch tires under it but probably NOT 12” wide. Anyone know of a good size like 33x10.5 or so? Can I fit 33’s under it without a lift? I don’t think that I will need nor will I get my Return on Investment for a suspension lift but I might want/need to put some small spacers on it for a body lift of 1.5 – 2”? Any thoughts on that? Just want to gain a little extra ground clearance, so 33’s will probably be fine for me and that way I won’t have to worry about re-gearing it either. I am also thinking about putting some after market fender flares on it too, so I can cut out the fenders if nec. To fit the taller tires. I guess what I am asking is, what if anything would I need to do to fit 33’s under it and if that sounds like a reasonable choice?
Thanks,
Old 05-13-2006 | 05:11 PM
Elton's Avatar
did you search ???
Old 05-13-2006 | 05:47 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
This has been covered extensively, use the search function for sure
Old 05-13-2006 | 06:25 PM
HUTCHSTACO's Avatar
u will not get 33's without a lift, also look up expaditions west, there is a forum for that too, his truck has narrow 33's bfg mt's 255/somthing/16 i think
Old 05-13-2006 | 06:58 PM
JGM's Avatar
JGM
Its preference, but putting on 33's without a regear will cause you to lose some guts. Its doable, but just as a heads up.
My suggestion - put stock size mud terrains on there and see how she does for a season, then plan out next season. You may be pleasantly surprised how well it does straight up.
Old 05-13-2006 | 07:05 PM
HUTCHSTACO's Avatar
or some 265/75/16 instead if stock 265/70/16
Old 05-13-2006 | 07:49 PM
SuaveGato's Avatar
Hello and thanks. I did search and continue to search... there is just so much info. and "speculation" on the subject that it seems to get convoluted...? I will keep looking and sifting through it but if anyone has anything to add, please do so. So far it looks like 32's are probably the "MAX" for a stock rig, but since I am willing to put on a small body lift and or fender flares, that adds more variables?
I was just hoping that maybe someone has put 33's on theirs, without a suspension lift and without rubbing and could tell me if I would need body spacers and or flares and what size etc.?
thanks for the info, I'll keep sifting through all of the topics from my search.
Old 05-13-2006 | 07:51 PM
SuaveGato's Avatar
P.S. I am hoping to keep the stock rims too... 15x7? I think? and I prefer narrower tires to wide ones... I do a lot in the snow and like to cut through it to terra firma, and the extra MPG is nice too.
thanks again,
Old 05-13-2006 | 07:59 PM
oly884's Avatar
Guest
255/85/R16 fit on the truck stock with some minor trimming in the back and a bit in the front. Fits on the stock wheels too.
Old 05-14-2006 | 12:02 PM
tc's Avatar
tc
Truck is probably plenty capable for what you want to do with the stock tires size. Put on some super swampers or Trxus M/T's and see how it does.
Old 05-14-2006 | 01:19 PM
SuaveGato's Avatar
Wink
Yeah, you're probably right, it will probably do most all of what I expect it to do with stock sized aggressive tread tires. Right now my rims are 15” though… I was just thinking that since I need new tires anyway, might as well up size a bit for some extra height & ground clearance and aesthetics too... Since I don't want to re-gear and lose top end speed, I know I can't go too big... was just hoping to maybe get some 32's or 33's under it? I also would like to do some suspension and or body mods... I don't know if I want to spend the $ on a full blown 4" IFS lift but have found some interesting posts on here about shackle kits, body spacers, and “beefier” front springs & shocks etc. that aren't too expensive and claim to give an excellent ride and add 1&1/2 - 2 inches.
https://www.yotatech.com/forums/show...ght=trd+tundra
I need new shocks too, so I might look into something like that with 32's ? With the 3.4 Ltr, 5 speed, do you think that I will lose that much power with stock gears and 32’s or 33’s? Just wondering?
thanks,
Old 05-14-2006 | 02:42 PM
tc's Avatar
tc
For what you're doing, spacers like Cornfed or Toytec would be sufficient. One of our OHTTORA guys has a '99 Taco running 33x10.50's with Fabtech coilovers (about 2" lift)and AR steelies. He thinks he could fit them stock height on the stock rims.
http://www.ttora.com/forum/showthread.php?t=34504
Old 07-14-2006 | 07:24 PM
kwikrnu's Avatar
I also did a search for fender flares and tire size. I'd like to know how the bushwacker cut out flares work with 33x12.5 tires. The bushwacker site says a lift is needed to run them... They look cool though and since my truck needs a paint job and body work it would be a good time for me to add them.
Old 07-15-2006 | 07:36 AM
kwikrnu's Avatar
I looked and didn't see much of anything concerning max tire size and bushwacker cut a fender flares. Maybe you can point me to the extensive coverage.
djpg2000
11-11-2020 04:56 AM
BeMiceElf
10-10-2015 09:40 PM
09-04-2015 09:27 AM
Yotoder865
07-09-2015 07:51 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Max tire size that will fit under 1996 Tacoma?
