Lower your truck for free?
You can remove leaves from the spring packs until the truck lays down on the bump stops.
Then. if you want the truck to be lower still, you can shorten , or remove the bump stops altogether.
Eventually, the truck will be laying on the tires in the fender wells.
Consult the Lowrider clubs in your area for further info.
Staff
I guess it is possible but if I wanted to lower mine, I would look into doing it the correct way. You are asking for problems when going about it the wrong way. Seen some heat springs up with torches and no way would I go about doing that.
voiddweller
19
05-02-2016 09:10 PM
87blyota
07-01-2015 05:26 PM
PureTacoma_Tundra
PureTacoma_Tundra
06-29-2015 09:45 AM
