Gap between engine and bell housing
I just replaced my 4runner 1987 22re with 5 speed. The Ex ended up with my last one. I knew there were leaks when I bought it. So I was just underneath trying to determine what I needed to do to fix the leaks when I noticed there is a gap on the lower half of the bellhousing to engine perhaps 3/16 of an inch at the very bottom then less till no more gap about up half way. So I hate to ask a dumb question is this correct? Do I just start torquing the bolts? It just seems odd the top half looks fine.
So I just checked the bolts are tight, the gap appears to be mostly just at the two lower brackets that go to the engine.
it looks like the stiffener plate is hitting the lip on the oil pan at first glance, ive heard of people having to tap the oil pan lip back a tad, if all the other bolts are really tight, you may have to loosen them a bit to get that gap to close, which sucks because the top 2 are a pain, that isnt a 4 speed trans is it?
Agreed, wash that sucker and then look for where leaks are coming from. Looking at it now, maybe it's a leaking rear main seal, and is dripping out the bottom of the bellousing.
Note that the 2 bellhousing bolts shown have much lower torque rating than the ones that bolt to the BLOCK. The ones you show bolt to the 2 mounts in the photo. How do I know? I snapped one once
That small gab is odd - could be the blocking plate got caught on something/bent at one point maybe?
I bet it has been like this since the new clutch was installed at a shop in Portland about 45K miles ago. I think the engine is leaking at the valve cover and I know the transfer case is also leaking at the rear seal because of worn bearings. I can grab the driveline and see the rear flange move at least a quarter inch. I am trying to decide about replacing the bearing and seal on the transfer case or picking up a used one for a c note. I also need to do a search about replacing gaskets on the engine.
ZONAYODA
07-13-2015 07:17 PM
Poncho0206
07-10-2015 06:21 PM
