fast idle issues 3.0
Old 05-25-2012 | 06:20 PM
slick3419's Avatar
1989 3.0 fast idle
so when the engine is cold and the fast idle is working the engine acts like it has a vacuum leak but only when the fast idle is working otherwise everything is fine. Ive checked for vacuum leaks very thoroughly and came up with nothing so whats the deal?does what part is the high idler?
Old 05-25-2012 | 09:48 PM
pholife's Avatar
if its not vacuum, then its your coolant temp sensor that is faulty causing the engine to think its cold all the time
also you might have a leak from your throttle body from adjusting screw...it should have a gasket around it and it usually goes bad....lastly make sure you take all the air out of your coolant/radiator...
Old 05-26-2012 | 11:15 AM
slick3419's Avatar
the fast idle shuts off when it should but theres a major hesitation when its on only, and my question was what would create that? its done this since I bought the truck and I have already replaced the valve cover gaskets so the plenum had to come off and when I hooked everything back up it still did the samething.
Charecter1
11-06-2023 10:08 AM
bigjstang
08-25-2021 12:41 AM
Sleaker
08-26-2020 06:03 AM
Alex Bessinger
08-31-2015 09:17 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: fast idle issues 3.0
