Do It YourSelf Quality Spray in Bed Liner?
Old 02-02-2016 | 08:41 AM
  #41
Swansen's Avatar
raptor liner seems pretty cool, namely because its a two part, but, they were thinking ahead with making a multi-part kit. add what you need to 1 of the 4 bottles in the kit, and if you need more, mix up another bottle, save the rest for later. seems fool proof as well with the mixing ratios.
However, as it is a urethane and not a polyurea, it doesn't have the best UV results, and i've found testament to that. saying that after 3 years, it gets all chalked and messed up from the UV(raptor liner). Also note Raptor liner is a no-go for roll on applications
http://www.monstaliner.com/monstaliner_comparisons.htm
just found this, these guys did a test of basically everything on the market. The note that their product is able to be rolled/brushed on and is perfectly UV stable. which is very rare for bedliner products.
Old 01-13-2017 | 12:36 AM
  #42
ericalar001's Avatar
If you are investing on<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->best truck bed liner then you should invest on spray also. Here I have reasons why you should spend your money in purchasing good spray. Check out below images in which reasons are explained.
Old 01-13-2017 | 11:16 AM
  #43
thefishguy77's Avatar
Your first post is pimping your business?
Old 01-13-2017 | 03:40 PM
  #44
old87yota's Avatar
A little spammy for a first post don't you think?!?
justdifferentials
14
06-11-2017 08:36 PM
gyroscope7
7
09-27-2015 08:39 PM
Gravel Maker
RuffStuff
09-08-2015 05:46 AM
djpg2000
09-07-2015 10:36 AM
Quick Reply: Do It YourSelf Quality Spray in Bed Liner?
