Dead cylinder
Old 07-02-2012 | 11:29 AM
parkerst02's Avatar
well got another question. I got a spare motor for it that spun a bearing they think its an 81 or 82 it has the double timing chain is that better than the single. and should i just go ahead and swap the head as well?
Old 07-31-2012 | 11:35 AM
parkerst02's Avatar
got it back together but now not firing up it will turn over and backfire and that is about it. I've done the timing and its on and its getting gas i don't know what else could be wrong any ideas
Old 07-31-2012 | 03:34 PM
Jasper 83's Avatar
Could your distributor be 180 degrees off?
Old 07-31-2012 | 08:48 PM
parkerst02's Avatar
Thats what it was i forgot that i put the distributor in after completely puting everything on . So i guessed when i put it in. Now to find out tomorrow how good it actually runs
Old 08-01-2012 | 07:31 AM
  #25
Jasper 83's Avatar
Hopefully you get it straightened out
Old 08-01-2012 | 08:13 AM
  #26
parkerst02's Avatar
well started it up today and it idles way to high what could cause that. Its like the gas pedal is to the floor how bad it is
Old 08-01-2012 | 12:17 PM
  #27
Jasper 83's Avatar
You may have a vacuum leak or the idle may need to be adjusted on the carb. The throttle linkage could be bound up too
Old 08-02-2012 | 11:44 AM
  #28
slow-mo's Avatar
On a cold engine, the rpms will be high at start-up because the Fast Idle Cam is engaged. Usually the rpms are around 2600-3000. As the engine coolant progresses to operating temperature, and the choke coil heats up, the rpms will lower on their own to normal idle speed.
Old 08-02-2012 | 02:24 PM
  #29
rokblok's Avatar
Thats pretty high... I understood that it was closer to 1200-1500rpm for a properly tuned/running engine/carb...
3000 RPM when the engine is cold and sucking for oil isnt a great thing to have happen....
Old 08-02-2012 | 05:52 PM
  #30
slow-mo's Avatar
I'm just the messenger.
Quoting from the FSM that's floating around here:
ADJUST FAST IDLE SPEED
Step D, adjust the fast idle speed by turning the fast idle adjusting screw.
Fast Idle Speed 3,000 rpm.
You can check yourself. It is in the Fuel System - Carburetor section, page FU-22. FU-22 is where the fast idle speed procedure starts, but the actual statement is on the next page, FU-23.
Old 08-02-2012 | 08:58 PM
  #31
parkerst02's Avatar
well its not the idler screw done tried that next will be vacuum leak and the motor shouldnt be cold it gets to around 105 and it never done it before this high. could the fuel pump be to strong it a manual pump but i put it on the old motor in it and it would flood it out sometimes
Old 08-03-2012 | 09:01 AM
  #32
parkerst02's Avatar
well i couldn't find a vacuum leak that changed anything. I don't know whats goin on i can hit the gas and its like it is suppose to run in high rpms but i know it isn't. I'ma desmog it in the next week or two and see if it changes it any. Unless anyone has any more ideas of what it could be
Old 08-03-2012 | 07:59 PM
  #33
slow-mo's Avatar
Scratch what I said, I just re-read the original poster engine, 1981 22R. What I posted was for a 1985 22R. I can't say if the rpms is the same for the Fast Idle Cam or not.
Old 08-20-2012 | 07:42 PM
  #34
4x4jeffyota's Avatar
Ever get it running right?
Old 08-24-2012 | 04:25 AM
  #35
parkerst02's Avatar
not yet i stripped a head bolt and threads in block trying to get it out and thought it could run without well its letting oil get in water and water get in oil so i got to fix it and i'm running out of ideas to how to fix it
Old 09-03-2012 | 11:40 AM
  #36
parkerst02's Avatar
well tapped a new hole for 1/2" got some all thread and welded a nut to it. Its still not running right i'm trying to time it right between the carb. and dist. but its starting to get really aggravating. Its also not starting on its own i have to put carb. cleaner in it to fire up but after that it runs on its own. Does anyone have any ideas of what it could be?
Old 09-07-2012 | 04:11 AM
  #37
parkerst02's Avatar
well finally got it fixed it jumped a tooth on timing chain. and i marked where the chain was on cam sproket while reinstalling so i didn't fix it i just kept it the same. Thank ya'll for all the advice and help it was greatly appreciated.
4.34runner88
02-07-2016 02:24 AM
TOYOTASC
09-10-2015 05:18 PM
old87yota
09-09-2015 12:39 PM
zz_denis
09-06-2015 03:43 PM
Squigglez
09-04-2015 07:33 AM
Quick Reply: Dead cylinder
