cranks but wont fire
i have a 94 4runner 4WD 3.0, this is my winter truck which usaly sits threw the summer. I make a point to to start the truck and run it for about 15 minutes atleast twice a week. Recentley i have been out of state for some time now and the truck has not been started in about 2 months, now i cant get it to fire. The starter cranks fine, im getting plenty of current from the battery, it just wont catch. Im pretty sure that this most be from bad gas sitting for two months and either clogging Fuel filter/lines, or from water build-up in the gas.
Any suggestions on how to get me toy to fire are greatly appreciated.
tried starter fluid to no avail. I beginning to think it may be a problem with cap/wires/plugs. The last time i started the truck i got a really strange fast passed clicking sound(not starter) that all my interior lights pulsed with. The next time i try to start the truck i got nothing, no starter click no interior lights NOTHING, turns out i had fried a
80A relay. I replaced the relay and now i get juice from the battery, but now i cant get the 3.0 to fire.
PLEASE HELP
PLEASE HELP
they have some sort of a gas restoreer.. or something i forget what it's called ill ask my friend and find out what it's called.... my prelude was sitting for a year and a half with blow piston rings so i asked him about a fuel going bad problem!
I would do a basic tune up. Change your spark plugs, wires, fuel filter, and get some new gas. I would also think about changing the oil since it was sitting for 2 months.
An off the wall easy test, switch the starter relay and the EFI relay.
If you need to cycle fuel through the lines or drain the tank, jump B+ and FP at the test point, Pull and put a hose at the FPR to a fuel can to drain it, Turn the key and you will hear the pump and see the flow.
Bourbonblues
12-15-2017 05:43 PM
anniesball
09-07-2015 11:20 AM
