Blown Head Gasket?
Blown Head Gasket?
What are the symptoms of a blown head gasket? Im not sure if this is what happened to me this morning, but the water was spraying out somewhere next to the thermostat, I couldnt see where it was coming from, but could feel steam from that area...The hose from the thermostat to the radiator is ok..The temp gauge was not reading hot at all, but water was all over...any thoughts would be helpful....thanks
Check your oil and your coolant level. If your oil looks like chocolate milk, it's a headgasket. Have you overheated recently? Not sure what hoses are near the thermostat, but it could be a bad thermostat gasket also,
White smoke in exhaust and chocalate milk oil or a couple symptoms. Sounds like you have an external problem if you are leaking and seeing steam as the head gasket would be an internal problem. Check all coolant hoses for cracks or breaks. Check the clamps to they could be loose. Good luck
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca
4x4-runner
12-27-2016 01:58 PM
