Sponsored by: CARiD
91 Toyota pickup clutch switch
Old 11-04-2015 | 08:55 AM
Timflav's Avatar
My truck is having issues with starting. The clutch wasn't engaging switch so I pulled out of harness and was engaging the plunger manually. That was working fine for a few weeks but stopped working. Replaced the switch but didn't solve problem. Used the clutch override and was able to start. Could this be a starter relay. Engine makes no noise without plunger depressed but makes a click when button depressed when attempting to start. Any ideas to trouble shoot this problem?
Old 11-10-2015 | 03:52 PM
moroza's Avatar
The clutch switch interrupts power to the starter relay, so what you're describing is normal behavior. You either have a bad switch or bad wiring to/from it. I bypass all of mine and would recommend you do the same.
jimmyjoebillybob
12-31-2017 10:44 PM
pickle6415
10-19-2015 08:08 AM
ErikZ1220
09-10-2015 04:53 AM
markf1
09-03-2015 01:23 AM
bobjohnson2121
08-28-2015 04:02 AM
Quick Reply: 91 Toyota pickup clutch switch
