Sponsored by: CARiD
89 pickup left tail light not working
Old 08-20-2015 | 05:25 PM
mudsicle's Avatar
Hi, I've done quite a bit of searching for this issue and it seems some people have somewhat common issues as I am. I've got an 89 pickup 4x4, and a few months ago my left taillight stopped working. The brake light, indicator, and reverse light still works. The right taillight works as it should. Fuses are all good. I thought maybe it was a bad ground, so I put the volt meter to the socket to test for voltage, but didn't get anything. I should mention that the bulb is fine as well. Is there anything else I should be checking for? I'm puzzled. Thanks!
Old 08-21-2015 | 12:59 AM
wyoming9's Avatar
Red face
Socket corroded ??
Physical damage to the wire for the tail light circuit
Your sure the bulb is good and the correct one??
Old 08-21-2015 | 03:03 PM
mudsicle's Avatar
Originally Posted by wyoming9
Socket corroded ??
Thanks for the reply Wyoming,
The socket is rusted on the outside, but the inside doesn't have any corrosion. I also made sure it's an 1157 however there is definitely damage to the circuit under closer inspection. The trailer harness has been sloppily installed, and there are a number of wires that have been cut- one being the tail light wire. Of course I can't get a reliable wiring diagram for this year either! So I'll have to get back under it after work today with my test light... I'll make a post if I solve it
Old 08-21-2015 | 11:51 PM
wyoming9's Avatar
Red face
Do yourself a favor get yourself a multi meter and don`t look back.
I would venture I have not used a test light in 30 years .
The second color is the stripe!!
White/black is the ground
Tail lights and marker lights should be green with license plate lights green/blue
brake lights are green/white
left turn is green /black
right turn is green/ yellow
back up lights red/black
gillesdetrail
11-19-2019 01:56 PM
gog1968
06-22-2015 06:55 AM
CLin9383
13
07-09-2002 03:45 PM
Corey
06-25-2002 12:13 PM
gtpman98
06-18-2002 07:48 PM
