Sponsored by: CARiD
86 4runner Flywheel bolt issue
Old 03-01-2016 | 11:48 AM
Nippon_surf's Avatar
In the middle of replacing my clutch. My 4runner has 133K, As there has been little off roading or abuse .. clutch had norma wear. So the Flywheel looks fine, and I didn't have luck breaking those bolts loose without Impact wrench.
My 3 options.
1. remount the new clutch & not resurface flywheel (i've read sanding is in option) -gamble
2. buy or rent impact wrench
3. Keep trying to leverage my 1/2" breaker bar to get it loose.
Thanks to anyone with suggestions.
Old 03-01-2016 | 11:53 AM
Any recommendations for a Impact wrench? air or electric!?! thanks
Old 03-01-2016 | 01:11 PM
MudHippy's Avatar
Save your money...for now. Hit 'em with a torch first. Some dumbass probably used red loctite on 'em. Get 'em hot enough, they'll come right out.
Old 03-01-2016 | 05:05 PM
Well I went and spent money and ended up with a used Snap On IM31 from the pawn shop. w$150 with guarantee Expensive yes, but 1/3 the price of new & BAM this thing is a keeper now thinking I will pair it with an onboard compressor for my expedition build.
Old 03-01-2016 | 05:11 PM
MudHippy's Avatar
So...it worked? You busted them loose with it? Was I right about the red loctite?
Old 03-01-2016 | 05:23 PM
Yes it worked easily. & no red loctite, this is the stock clutch I'm replacing.
btu44
10-07-2016 09:03 AM
Henrythewound
13
01-12-2016 08:18 PM
ToYoda49
12-27-2015 04:04 PM
SunnyCoastSteve
12-17-2015 07:52 PM
Zealous84milo
12-15-2015 04:08 PM
Quick Reply: 86 4runner Flywheel bolt issue
