3.4 swaps
3.4 swaps
I'm having issues with my 3.4 swap on the idle. It's at a high idle and I've messed with all the vaccum lines plugged and plugged in and it seems to just stay at 2000 rpms. Has anyone else ran into this issue. My motor is out of a 2001 Tacoma. Any info will help thanks.
Did you do the timing belt perhaps the cam timing is off.
Wiring glitch in the harness??
You have allowed this to warm enough so the coolant temp sensor reads hot enough to shut the The IAC??
Failed coolant temp sensor keeping the IAC open.
What is the coolant temp sensor reading ??
Yeah gets pretty warm. The gauge get to where it reads at normal temp. I doubt its glitch. Toyo only swaps did the harness. I didn't have the full exhaust hooked up. Could that be if the o2 sensor isnt getting any flow?
The temperature gauge and the coolant temp sensor are different
If the coolant temp sensor is not working correct could just be corrosion the ECM will keep the Idle Air Valve open
The idle Air valve could also be stuck in the open position.
Bad ECM could be the cause of this as well.
I went through 2 before I cured my problems.
Flying91
45
04-11-2024 05:39 PM
LosPatosDelSur
23
03-12-2021 04:08 AM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 08:15 PM
