22re timing pulley mark 180 off
Hi all,
I just got done with a full rebuild and got the truck started but somethings not right. I'm pretty sure the cam timing is right (rockers loose when #1 piston is up) and that I have installed the distributor correctly. It cranks for about 4-5 seconds then catches after I push the throttle, runs rough for a minute then smooths out some, still not real good. I couldn't time it properly last night cause the mark was jumping around/not visible. Well, I shoot the light at it again tonight but this time I wonder where the mark went. I get down on my knees and point the light up at the pulley and the mark is directly on the bottom of the pulley I.E. 6:00! I don't know how I messed this up, any advice would be appreciated.
Hi all,
Good luck hope this helps
Thanks for the reply and for reminding me to update! It turns out that timing was at 0* my timing light was getting interference because I had the pickup too close to the distributor. I placed the pickup near the spark plug and the timing light functioned properly.
Still have a hard start and rough idle but that's a different problem I need to track down.
The hard start turned out to be the fuel pressure regulator. I installed a new one and it was bad out of the box. Within spec with the engine running but as soon as I shut it off the fuel would drain out through the regulator.
Chuckwild
11-19-2015 04:03 PM
Runnin13s
11-05-2015 08:45 PM
allkine
11-04-2015 02:32 AM
bennyt4130
11-03-2015 09:44 AM
